CSV output
  • October 19, 2022
  • 183 views
giuseppecfgeo
Hey community!
How can i export CSV output without attribute name? I am transforming a CSV file with East North coordinates but in output the first data is the name of the "_result" attribute that I would like to delete (attached image).
Thank you!
danilo_fme
Forum|alt.badge.img+44
  • October 19, 2022
Hi @giuseppecfgeo​
When you insert the Reader CSV, you can "eliminate" the line that you wan't:
Parameters - Field Names Line:2
Reader
Thanks,
geomancer
Forum|alt.badge.img+47
  • October 20, 2022
True, but not all that relevant for the CSV Writer 😉
The CSV Writer has an option in the Parameters to 'Write Field Names Row'. When you set this parameter to 'No', no header row gets written.
CSV_Writer_Parameters
  • October 20, 2022
@giuseppecfgeo​ It looks like you might be better off using the Text File writer. My guess is that your building the comma separated list in FME as a single attribute. If that's the case Text Line is a better fit. than CSV.
