I want to write data to an Autocad object data writer. It will not finish translation and the text "Object Data Reader: Failed to load object data handling module. No object data will be read" appears in de log file. There is a notification that says:
File C:\\Program Files\\FME\\metafile\\autocadCorrTemplate.fmi could not be opened
It happens in 2017.x and 2018.x. I have checked if the file exists in that folder. It doesn't. There are two other files that are called "autocadCorrTemplateDestination.fmi" and "autocadCorrTemplateSource.fmi".
Strang thing is that colleagues in various FME versions not having this problem. One has the same device I have.
Who knows why my workspace is fails?
FME version: 2018.1 64-bit smallworld license
Because the translation fails, I have turned on logging with debug.
