Creating unique values based on ranges
Hi all,
If have an issue creating a unique column for a range of points. The points are separated (based on calculations) in ranges that run from 3 to 2, all the point within this range have 1 values (for example 3,1,1,1,2). I would like to generate a new column containing for each range an unique id. See my example columns down below, showing the preferred result:
UUIDRangesPreferred ResultA31A
11A
21A
A
32A
12A
22B33B
13B
13B
23C34C14
Is there a way to calculate this final column?
Forum|alt.badge.img+39
  • December 2, 2019
So the features are in order and the first feature always has a range value of 3?
You can use adjacent attribute mapping to increment a group number everytime 3 is encountered
Probably easiest to deal with the range with value '-' afterwards
gazza
  • December 2, 2019
A couple of ideas, you could use a StatisticsCalculator grouping by Range and look at the _count value coming out of the Cumulative port.
Or use a Counter where the counter name is dynamically generated using range, such as counter_@Value(Range)
