Creating report based on when jobs were still open
  • Aug 9, 2019 12:18 AM UTC
  • 33 views
I have some data in the following format:
Job
Raised
Closed
1
20190715
20190825
2
20190611
20190825
3
20190614
20190825
I want to get a summary table, about for each month, how many jobs I had open. So for the above data it would be:
Month
Raised
Closed
Open
June 2019
2
0
2
July 2019
1
0
3
August 2019
0
3
0
I can do the raised and closed, but am struggling with the open. I tried using a testfilter, with a lot of if statements, which works, but then I not sure how to export that into a format that i can use the data.
Help :)
Forum|alt.badge.img+63
You can split both the Raised and Closed dates into year-month-day (AttributeSplitter or some SubStr expressions in the AttributeManager), if the raised/closed day, month or year values are different it should count as an open job. Then duplicate it (month closed - month raised + 1) times and then count them.
