creating geometry
  • Jun 10, 2020 11:15 PM UTC
  • 85 views
curtisd54
Forum|alt.badge.img+5
I need to create geometry for records which were merged with other data.
records with Geometry from SHAPE.STLength - below
records with no Geometry from SHAPE.STLength - above
This is the process with the transformers at the top is where the geometry records are not showing up after they were merged with supplier data
Forum|alt.badge.img+63
Can you share a bigger screenshot of your workspace? It's really hard to make out what's going on. Also a bit of background information (like source data formats) would really help us come up with suggestions.
curtisd54
  • Jun 11, 2020 4:05 PM UTC
the data is in a ESRI shapefile format, I have included a larger image
fmelizard
Forum|alt.badge.img+22
  • Jun 11, 2020 10:10 PM UTC
Hi @curtisshane In the FeatureMerger is the "Feature Merge Type" parameter set to "Geometry" or "Attributes and Geometry"?
