Creating custom cross-table unique values
  • Oct 22, 2021 1:56 PM UTC
  • 66 views
tim_bkr
Participant
Forum|alt.badge.img+5
I'm creating objects in 5 different tables and I have a requirement for the object's IDs to be unique accross all 5 tables. I also need to set the starting ID value with a UserParameter
Suppose I had 3 features created in each table.
My objective would be :
Ids 1 to 3 in table A
Ids 4 to 6 in table B
Ids 7 to 9 in table C
Would anyone have a suggestion for the best way to do this?
I've tried with counters and feature holders but I haven't been successful. Strangely, I get something like
table A : 1,2,3
table B : 1,2,3
table C : 4,5,6
although it seems to me I'm doing the exact same thing between table A and B and between table B and C...
Cheers !
Forum|alt.badge.img+54
  • Oct 22, 2021 2:26 PM UTC
As long as your counters have the same name and the scope is set to global you shouldn't have to do anything more
tim_bkr
Participant
  • Participant
  • Oct 22, 2021 3:01 PM UTC
I see. So you have to set "Count start" to 0 although you expect it to continue from where the previous counter (with same Counter name and Global Count Scope) finished. That's what I've done now and it works.
Thanks ebygomm.
