Creating a 'report' from data from a SQL db which shows a count of data collected on a weekly basis. The week starts on a Wednesday.
  • May 20, 2021 5:18 AM UTC
  • 27 views
I have a sql table with a date field.
it shows Lab Code (MINA / Intertek), sample ID, Lab_report_date
I want to show this data as a table or export such as:
Capture
The week is not calculated as a standard 'week', but from Wed - tuesday.
I've been playing around with DateTimeCalculator & Attribute Pivoter without much luck.
Is this even possible?
thanks
@tdunlevie​ can you use DateTimeConverter convert the date to a day of the week (%u) - you'll need the year in the date - and then use a lookup (AttributeValueMapper) to move the Monday based (1-7) to a Wednesday based (1-7) and go from there?
