Creating a line between two nearest points
joshuadamron
Forum|alt.badge.img+7
I've searched for a solution to this but none of the other posts seem to provide the minor detail I'm missing.
My goal: I need to find the distance "as the crow flies" between street intersection points (point geometry features).
What I have: Street Intersection points feature set with a unique ID field populated for each point.
What I've done: [1a] NeighborFinder (Street Intersection points as both the Base & Candidate inputs) [1b] Vertex Creator using the Nearest neighbor output ( Mode= Add Point ; _closest_candidate_x & _closest_candidate_y)
[2] LineBuilder (inputs are the original Street Intersection points and the Vertex Creators output points) grouping on the unique ID field. However this process does not output any lines. What am I missing?
Best answer by erik_jan
Step 1b should create a line between the point and its nearest neighbor (point a, adding point b creates a line)..
You should not need step 2.
bruceharold
Forum|alt.badge.img+17
  • April 26, 2018
erik_jan
Forum|alt.badge.img+18
  • April 26, 2018
erik_jan
  • April 26, 2018
On second thought, the closest neighbor for a point (if all points are fed as base and candidate) is the point itself. Therefor it will not create a line.
You will need to find the closest 2 points and use a list.
The connect the _list{1}._closest_candidate_x and _list{1}._closest_candidate_y in the VertexCreator.
erik_jan
  • April 26, 2018
See this image
fmelizard
Forum|alt.badge.img+19
  • April 26, 2018
@joshuadamron
To get the distance, use a LengthCalculator after the VertexCreator
joshuadamron
  • April 30, 2018
Thanks, you nailed it, connecting the right list outputs in the VertexCreator was my glitch. I dropped step 2.
