Creating a large 3D Cone shape as a shapefile for ArcGIS on-line 3D viewer
  • Nov 26, 2025 4:35 AM UTC
  • 142 views
bhindustry
Hi FME Community,
I’m working on a project where I need to create a 3D cone shape in FME 2025 and publish it to ArcGIS Online 3D viewer. The cone should:
  • Start at ground level (let’s say Cape Canaveral X, Y, Z coordinates).
  • Have a base radius of 500 m.
  • Extend in a cone shape getting wider upwards at a 7° angle.
  • Reach approximately 50 km into space (so it’s a very tall, tapered cone).
I’ve tried using combinations of Creator, Taper Line Bufferer, Rotator, and SurfaceBuilder, but I’m struggling to generate the correct geometry and export it in a format that ArcGIS Online accepts (e.g., Collada, OBJ, or multipatch).
Challenges I’m facing:
  • Generating the circular base and apex points accurately.
  • Applying the 7° tilt without breaking the geometry.
  • Ensuring the output works in ArcGIS Online’s 3D environment.
Has anyone successfully built something similar in FME?
  • Which transformers or workflow would you recommend?
  • Any tips for handling such large Z values (50 km) and coordinate systems?
  • Variable input items into the Workspace such as: Ground X, Y, Z - cone max height, - cone angle of growth, etc.
  • Best practices for exporting to ArcGIS Online?
Any advice, examples, or workspace snippets would be hugely appreciated!
Thanks in advance, Here’s a rough image of a cone area which has a shape that represents a safe rocket launch buffer. Note this is all made up and in no way real.
daveatsafe
Forum|alt.badge.img+24
  • Jan 6, 2026 5:20 PM UTC
Hi ​@bhindustry,
I am attaching a workspace containing the custom transformer LaunchConeReplacer, that will create the launch cone surface for you, and output to a Shape multipatch. I have annotated all the transformers within the custom transformer for clarity, but the basic process is:
  • Store original point location
  • Replace with 0,0,0 point
  • Calculate top radius from bottom radius and cone angle
  • Create arcs on bottom radius and extract endpoints
  • Create arcs on top radius
  • Extend top arc with bottom arc endpoints to create polygon
  • Convert polygon to face
  • Merge faces into surface
  • Move surface to original location
daveatsafe
  • Jan 6, 2026 11:21 PM UTC
I have modified the custom transformer to be more generic and published it to FME Hub: https://hub.safe.com/publishers/safe-lab/transformers/conereplacer. It will now replace a line segment at any orientation with a 3D cone as a Surface or Solid.
bhindustry
  • Jan 12, 2026 5:00 AM UTC
Hi Dave - Thanks for this, I really appreciate your efforts, I just might need a bit more help in using it. I have tried a number of different things with one or multiple input points and I just can’t get it working.
I keep getting an ‘invalid geometry’ response when I try it out and it fails at the first Geometry filter. If for example I had the attached XLS file with three Lat Long points that I want to create cones from. How would I use it?
Are you able to create a demo workbench that uses your new Cone Replacer transformer?
Regards
Brendan
daveatsafe
  • Jan 12, 2026 4:44 PM UTC
Hi Brendan,
Thank you for the feedback. I have modified the workspace to force the input Excel points to 3D and reproject to Florida State Plane meters before creating the cones. Lat/long doesn’t work well for 3D since the the XY and Z coordinates are in very different units (degrees vs feet/meters).
Please try the updated workspace.
