Hello to all forum members,
I am looking for a solution for searching on a point cloud (*las) of a set with parameters:
1. The height of the set of points does not differ from each other by 0.03 [m], (flat surface) 2. The set creates a rectangular plane with an area of not less than 25-30 [sqr m], (5x5, 4x7 etc.)Below the workflow on which I stopped.
Thank you for your help.
