Creating a flat surface on lidar data
  • Oct 4, 2018 7:50 PM UTC
  • 100 views
piotrek6116
Hello to all forum members,
I am looking for a solution for searching on a point cloud (*las) of a set with parameters:
1. The height of the set of points does not differ from each other by 0.03 [m], (flat surface) 2. The set creates a rectangular plane with an area of not less than 25-30 [sqr m], (5x5, 4x7 etc.)
Below the workflow on which I stopped.
Thank you for your help.
Best answer by piotrek6116
@gio
Thanks for answer.
I agree for negative rule in work-flow, but found "PlanarityFilter" it's tools usefull.
gio
Forum|alt.badge.img+15
  • Oct 5, 2018 12:48 PM UTC
looks like you are attempting to shave of points which are within 0.03 from the top or 0.03 from the bottom of the point cloud.
As max is...max.. the second rule will yield a negative number.
And maybe there are none within this range yuo set?
piotrek6116
  • Oct 18, 2018 8:35 AM UTC
@gio
Thanks for answer.
