Creating a circle through all vertices of a triangle
  • Sep 19, 2017 9:56 PM UTC
  • 7 replies
  • 192 views
Hi All,
How would I go about creating a circle where the perimeter passes through all three vertices of a triangle?
I've attempted to use the Minimum Spanning Circle Replacer, but this creates a circle based only on the longest side of the triangle.
Any ideas would be greatly appreciated.
Thanks
This might help:
http://paulbourke.net/geometry/circlesphere/
Scroll down to "Equation of a Circle from 3 Points"
jdh
Forum|alt.badge.img+41
  • Sep 19, 2017 10:49 PM UTC
Edit: This deals with the edge cases where two points are aligned vertically, two or more points are coincident and if there is anything other than 3 points
circlefrom3points.fmw
  • Sep 20, 2017 1:21 AM UTC
I would try this with a PythonCaller.
# PythonCaller Script Example
# Replace feature's geometry with a circle created from its first three vertices.
# Assume the input feature has a geometry having three or more vertices.
# The three vertices should have different coordinates, and any one of them
# should not be on the straight line passing other two vertices.
import fmeobjects
def createCircleFromThreeVertices(feature):
    coords = feature.getAllCoordinates()
    threeVertices = [fmeobjects.FMEPoint(*p) for p in coords[:3]]
    arc = fmeobjects.FMEArc(tuple(threeVertices))
    arc.setSweepAngle(360)
    feature.setGeometry(fmeobjects.FMEEllipse(arc))
  • Sep 20, 2017 1:49 AM UTC
This worked perfectly, thank you!
  • Sep 20, 2017 8:07 AM UTC
import fmeobjects
Elegant and minimal, I like it. The PythonCaller might also be followed by an ArcStroker if the destination doesn't support arcs.
  • May 10, 2019 9:38 PM UTC
import fmeobjects
This worked great for generating closed arcs (circles) but in attempting to output arcs with a start/end point and changing the sweep angle value it always returns a closed arc having the same start/end point.  Its as if the arc.setSweepAngle(x) statement is ignored?  What am I missing?
import fmeobjects
def createArcFromTwoVertices(feature):
    twoVertices = [fmeobjects.FMEPoint(*p) for p in coords[:2]]
    arc = fmeobjects.FMEArc(tuple(twoVertices),rad,False)
    arc.setSweepAngle(sweep_angle)
fmelizard
Forum|alt.badge.img+22
  • May 15, 2019 11:05 PM UTC
import fmeobjects
Hi @wallace You can create an Arc by 3 Points without Python, using an FMEFunctionCaller:
@Geometry(SET_PROPERTIES, ARC3POINTS,
      [<startX>], [<startY>], [<startZ>],
      [<midX>], [<midY>], [<midZ>],
      [<endX>], [<endY>], [<endZ>])
