Create tiles from .ecw for every individual polygon
  • Jan 23, 2019 3:05 PM UTC
  • 162 views
Hello,
I want to extract individual tiles/images with a fixed dimension (pixels x pixels) from an orthomosaic file (.ecw format), containing a single building in the centre of each tile/image. I do have a shapefile containing all building footprints but a can figure out how to approach this.
Can someone help me or give me some tips?
Thank you!
Best regards,
Bram
itay
Forum|alt.badge.img+19
  • Jan 23, 2019 3:11 PM UTC
Hi @brmschipper, I would use the clipper with your inputs, just make sure that the footprints are buffered a bit so the you dont miss some info.
Hope this helps.
Forum|alt.badge.img+63
Generate a centerpoint for each building then use the 2DBoxReplacer to make a polygon centered on that point with the size you want, then use that as input for the clipper as @itay suggested.
gio
Forum|alt.badge.img+15
  • Jan 23, 2019 4:50 PM UTC
@brmschipper
I would use a BoundingBoxAccumulator grouped by the building id. Then scale them to your required size.
  • Jan 25, 2019 10:34 AM UTC
Thanks! Worked perfect!
