create table from attribute .json
Hello,
I have created an API call with a .json file, however, I am struggling to process these attributes (after having used JSON Flattener), I think it should be easy but I cannot get it.
Attached the image, I would like to have the list of attribute that appears on the right side as a proper table in which each row means a different element.
Could anyone please help with this?
Thank you very much
  • March 8, 2018
Hi @claraosuna, a possible way is to expose the list members ("array{}.date", "array{}.id", "array{}.incr", .. etc.) with the AttributeExposer, and then use the ListExploder to transform the feature into record features for each element in the list.
  • March 8, 2018
In the JSONFlattener, make sure you manually expose the array{} list attribute, then use the ListExploder to create one feature per list element.
If necessary, you can also add an AttributeExposer for the list element attributes.
  • March 8, 2018
Hello @takashi and @david_r,
thank you very much for your response, I truly appreciate them.
I am trying to follow the workflow but I must be doing something wrong since I don't get anything successful, I attach the file
It is the first time that I use both tools so I am not quite sure how they work.
Thank you very much
  • March 8, 2018
Try removing the double quotes in the AttributeExposer.
  • March 8, 2018
It worked!!
Thank you very much.
