Create schema for CSV file
  • March 15, 2019
  • 67 views
nedwaterman
Forum|alt.badge.img+9
I'm trying to read in a CSV file that has no header information. Additionally the data is spread around several columns rather than in a single line.
Looks like the first row is junk.
The second is the site name.
The third is the site number.
Fourth is pressure information
Fifth is the date and start time of the data
6 onwards is the data
How do I first create a schema that FME uses before it tries to open the file? I attach a file as an example.
Thank you.
  • March 15, 2019
Not clear what you need to accomplish.
If you just need to read data rows, you can configure the schema through the reader parameters dialog when adding the CSV reader to the workspace. e.g.
