Create Random Points with based Attributes values
  • October 10, 2017
  • 6 replies
  • 238 views
venu
Forum|alt.badge.img+5
Dear All,
I have 6 Polygons in one shapefile with Name Block A to Block F.
Also, I have one excel file for materials location like shown below screenshot.
my aim needs to create a random point within the polygon as per the values mentioned in the table.
For Example:
121 Sand Random points for Block A polygon
6182 Sand Random points for Block B polygon
1 Cement Random points for Block A polygon
210 Cement Random points for Block B polygon
all points if possible one single shp file.
Thanks in Advance
Venu
Best answer by geosander
There already seems to be a custom transformer on FME Hub (by @takashi, unsurprisingly) that might be helpful here.
  • October 10, 2017
A possible solution could include
  • Cloner to create multiple features, e.g. 121 Sand features for block A.
  • BoundsExtractor to get min/max X/Y values for the polygon
  • Two RandomNumberGenerators to generate min/max X/Y values inside the bounds and a VertexCreator to create a point based on those values
  • SpatialFilter to check if random point is inside (if not, loop) if the blocks aren't perfectly rectangular and oriented north/south
geosander
Forum|alt.badge.img+7
  • October 10, 2017
  • October 10, 2017
Great find!
gio
Forum|alt.badge.img+15
  • October 10, 2017
@venu
this will prevent you having to do lots of iterations when using complex shapes:random-point-in-polygons.fmw
No iteration, just setting high enough resolution in grid builder...
gio
  • October 10, 2017
@venu
for instance
gio
  • October 10, 2017
refined the workbench to cope with more complex forms.
At resolution of 50 all 100 points are inside in 1 go!
