Create polygons from lists
  • Nov 22, 2018 3:36 PM UTC
  • 16 replies
  • 576 views
This seems as though it ought to be really simple but I can't figure out how to do it.
I have a number of text files which each define a polygon by listing the coordinates of its vertices. I'd like to build polygons from the coordinate lists.
Usually I'd use the VertexCreator to build points/polygons but I can't figure out how to get it to iterate through a list of variable length.
Some of the lists are also quite long (20+ coordinates) and it seems there should be an easier way than adding 20+ VertexCreators in series!
  • Nov 22, 2018 3:39 PM UTC
Some vertex lists can be automatically parsed by FME, if they conform to some standard such as WKT.
Could you please post an example of such a coordinate list here?
  • Nov 22, 2018 3:44 PM UTC
The solution depends on how the coordinates are listed in a text. Could you please post a sample text that illustrates the format of coordinates list?
@david_r thanks for getting back to me. Here's a list:
PLY/1,54.3671208915,10.1422463646
PLY/2,54.3700921435,10.1422584956
PLY/3,54.3700947237,10.1537959675
PLY/4,54.3693817722,10.1537945973
PLY/5,54.3693818426,10.1541095477
PLY/6,54.3688144656,10.1541084576
PLY/7,54.3688143977,10.1537935091
PLY/8,54.3671234716,10.1537838354
This is actually part of the metadata of a BSB file. The BSB reader in FME doesn't seem to pull in much of the file as attributes so I'm reading it in as a text file to access this data and using a stringsearcher to identify these coordinate pairs. So, this is part of a file with lots of different information in it.
@takashi I've posted a sample below from one of the files. It's part of a BSB header so contains all the standard BSB header info but the BSB reader doesn't read this data in. Therefore I'm reading it in as a text file. I'm trying to extract the PLY polygons.
  • Nov 22, 2018 3:58 PM UTC
We'll need a bit more context, how is the list represented in your workspace?
gio
Forum|alt.badge.img+15
  • Nov 22, 2018 3:59 PM UTC
@erinjayaustin
if they are ordered would a LineBuilder not suffice? Group by/connection break attribute = fme_feature_type
(make sure last coord = first coord of course) If they close they become polygons.
I'm using 2 string searchers to extract the x-coords and y-coords, which creates a list of the subexpression matches. I've attached an image of what the 2 lists look like for this feature.
I'd like to plot the points (x-coord{n}.part,y-coord{n}.part).
  • Nov 22, 2018 4:18 PM UTC
Here's a possible solution using the PythonCaller:
def GeneratePolygon(feature):
    x_coords = [float(x) for x in feature.getAttribute('x-coord{}.part') or []]
    y_coords = [float(y) for y in feature.getAttribute('y-coord{}.part') or []]
    feature.addCoordinates(zip(x_coords, y_coords))
Add a LineCloser after the PythonCaller.
Thanks. I'll give this a go and see how I get on.
  • Nov 22, 2018 10:58 PM UTC
Other approaches.
You can convert the two lists to a single structured list consisting of two members (e.g. "_coord{}.x" and "_coord{}.y") with the AttributeManager (Rename Action), then explode the list (ListExploder), create vertices (VertexCreator), build a line (LineBuilder) and finally close the line to form a polygon (LineCloser).
Alternatively, the JSONTemplater with this template expression creates a GeoJSON object representing a polygon. You can replace it with a polygon geometry using the GeometryReplacer (Geometry Encoding: GeoJSON).
let $xs := fme:get-list-attribute('x-coord{}.part')
let $ys := fme:get-list-attribute('y-coord{}.part')
return
    "type" : "Polygon",
    "coordinates" : [
            for $i in (1 to count($xs))
            return [xs:double($xs[$i]), xs:double($ys[$i])],
            [xs:double($xs[1]), xs:double($ys[1])]
  • Nov 22, 2018 11:27 PM UTC
Be aware that the script would throw an error If the Python Compatibility was set to 3.x. with Python 3.x, you should modify the last line. e.g.
    feature.addCoordinates([(x, y) for x, y in zip(x_coords, y_coords)])
Other approaches.
return
    "type" : "Polygon",
    "coordinates" : [
Thank you very much @takashi, this worked for me!
I couldn't get this to work, but I don't know Python very well! When I have a bit more time I'll have another go as I like to be able to understand everything in my workspaces! Thank you for the help.
runneals
Forum|alt.badge.img+32
  • Jul 31, 2020 5:57 PM UTC
Put together this transformer that makes a line, but I think making a polygon would be just as simple :) https://hub.safe.com/publishers/runneals/transformers/listlinebuilder
For anyone else trying to solve this, I had a similar issue where I wanted to create 40 simple rectangular polygons without using a reader. I came up with the following solution, which isn't particularly elegant, but it gets the job done! I hope I've covered all the parameters that matter.
Creator
  • Number to Create: 1
AttributeManager
  • Output attribute: coordinates
  • Output value: text with x0 y0,x1 y1,x2 y2,x3 y3, x4 y4, ... , x0 y0 on each line (first and last coordinate pairs are the same)
AttributeSplitter
  • Attribute to split: coordinates
  • Delimiter or Fomat String: [new line]
  • List Name: _coordinate_list
ListExploder
  • List Attribute: _coordinate_list{}
  • Element Index: _polygon_index
AttributeSplitter_2
  • Attribute t split: _coordinate_list
  • Delimiter or Format String: [comma]
  • List Name: _coord_pair
ListExploder_2
  • List Attribute: _coord_pair{}
  • Element Index: _polygon_coord_index
AttributeSplitter_3
  • Attribute to split: _coord_pair
  • Delimiter or Format String: [space]
  • List Name: _x_y
VertexCreator
  • Mode: Replace with Point
  • X Value: _x_y{0}
  • Y Value: _x_y{1}
LineBuilder
  • Group Processing: Ticked
  • Group By: _polygon_index
If the LineBuilder outputs a Line, your first and last coordinates aren't the same. Otherwise you should have polygons good to go.
