Create polygon from string of coordinates
  • Jan 8, 2024 11:53 AM UTC
  • 5 replies
  • 839 views
geovision
Forum|alt.badge.img+5
I have XML file with features I'm trying to read.. that works. Next step is to create a polygon for each feature, I have a string with points that make the polygon. String looks like this:
173363.252 587903.412 173363.369 587902.665 173362.055 587900.798 173363.867 587888.745 173364.007 587887.815 173371.744 587888.843 173368.618 587904.7 173363.252 587903.412
That's a list of x and y coordinates, now I can't figure out a idea to make polygons from it. Any ideas? Do I have to seperate them, create lines and make a polygon from it? Any help is appreciated.
Best answer by dustin
This is what I would do:
  •  With a StringSearcher, use the regex below to extract the coordinate pairs into a list using the All Matches List Name.
([\d.]+) \s*([\d.]+)
  • Using a ListConcatenator, concatenate the list in a single attribute with a comma as the Separator Character between each coordinate pair.
  • Use a GeometryReplacer with OGCWKT encoding with the following Geometry Source to build the geometry.
POLYGON((@Value(_concatenated)))
joepk
Forum|alt.badge.img+22
  • Jan 8, 2024 1:05 PM UTC
Hello, the workflow outline you sketched is indeed the way to do this. I did the following:
imageimageimageThere is probably an easier way to do this, but this works pretty good.
imageHope this helps
P.S: RD New spotted 😎 veel plezier!
dustin
Forum|alt.badge.img+36
  • Jan 8, 2024 1:19 PM UTC
joepk
  • Jan 8, 2024 1:27 PM UTC
:o Very cool!
geovision
  • Jan 9, 2024 6:34 AM UTC
Thanks! Worked like a charm.
eldonmarks
  • Feb 9, 2024 8:51 AM UTC
Thank you so much for the solution, those suggestions solved my problem also.
