Create polygon from point
ingalla
Forum|alt.badge.img+10
fmelizard
Forum|alt.badge.img+18
  • May 22, 2016
mygis
Forum|alt.badge.img+13
  • May 24, 2016
Hi @ingalla, I have created a transformer and put it in the store/hub, open your FME 2016.1 and search for RectangleCreator. You will need to set the width, height and the rotation (if required). Hope this works for you.
Fantastic Tool!! Congratulations ^^
  • March 30, 2017
Hi @ingalla, what kind of polygon do you need to create from point(s)? e.g.
  • Bufferer: creates a buffer area for each point.
  • HullAccumulator: creates a convex or concave hull that contains given multiple points.
  • VoronoiDiagrammer: creates Voronoi domains for each point.
Other?
erik_jan
  • March 30, 2017
I would use the Bufferer transformer.
And use the "Square buffer" mode to create rectangles. Using the "Round buffer" mode creates circles.
  • January 24, 2022
very useful, thank you
