create polygon from point.
  • May 10, 2019 1:48 PM UTC
  • 42 views
marcoroose
Forum|alt.badge.img+9
I want a polygon that contains all points per group. (postcode)
BUT the polygon may NOT contain points from another group.
I want the maximum area. but it must not overlap.
I have used the HullAccumulator but I get an overlap with that.
the red line is what i want.
Forum|alt.badge.img+54
  • May 10, 2019 1:59 PM UTC
For this sort of scenario I'd use a VornoiDiagrammer to create polygons round each point, and then dissolve based on postcode to create postcode areas
