Create points every 100 feet along Line
  • Feb 14, 2018 4:48 PM UTC
  • 970 views
I have a pipeline featureclass from SDE that I would like to create points on top at every 100 feet. I've tried Snipper, LineDivider, etc but not getting desired results. Thoughts?
Thank you
Hi @jbears40,
I believe there is a custom transformer available from FME Hub called the DistanceMarker_2013 that might do the trick. Please try adding this one to your workspace and let us know how it goes!
Cheers,
Annabelle
  • Feb 14, 2018 5:17 PM UTC
Hi @jbears40,
Cheers,
Annabelle
Thanks Annabelle but I still must be missing something because I'm not getting points every 100 feet (see below images). Am I missing other transformers to work with the DistanceMarker_2013? I should have 50,000 points or more I estimate
  • Feb 14, 2018 5:37 PM UTC
I needed to project my pipelines and then it worked. DistanceMarker did the trick, thanks Annabelle!
That's great news @jbears40! Glad it worked out. Projections are tricky beasts sometimes!
