create point cloud from overlapping polygons
  • September 23, 2013
  • 13 views
Hello,
I have a set of overlapping polygon features in 3D space. I'd like to create a point cloud from these polygons without overlapping points. I used the "PointCloudCombiner" but the transformer "rasterizes" each polygon individually. How can I avoid this and achive a pc without several overlapping points?
Just an idea:
1) Create a point cloud from the polygons.
2) Transform the point cloud into 3D points.
3) Select one point from each overlapping points.
4) Create a point cloud again from the points.
Takashi
  • September 25, 2013
Hi Takashi,
thank you for your idea, but it does not work. The points (step 3) do not overlapp.
Is there a way to drop point clouds from top onto the overlapping polygons? This should result in points only in the highest polygon of each polygon cluster.
Borone
fmelizard
Forum|alt.badge.img+17
Do an AreaOnArea overlay first -- that will end up giving you a set of polygons that don't overlap. Then convert those to points using PointCloudCombiner (I think) -- you should be in business.
