Create multiple geometry with XML
  • Oct 22, 2019 2:02 PM UTC
  • 76 views
philippeb
Forum|alt.badge.img+23
I'm trying to create multiple geometry with XML.
I'm using GeometryReplacer to create my geometry.
My XML looks like this, but it seems that I can't create more than 1 geometry... Why??
Functions aren't supported more than once??
I don't want to use a Creator for each geometry... any solution?
Thanks!
<?xml version="1.0" encoding="US_ASCII" standalone="no" ?>
<geometry>
    <arcBy3Points>
            <startCoord x="100" y="0"/><midCoord x="80" y="40"/><endCoord x="50" y="50"/>
    </arcBy3Points>
    <line>
            <coord x="50" y="50"/><coord x="100" y="50"/>
    </line>
</geometry>
Best answer by daveatsafe
Hi @philippeb,
You can only create a single geometry in the GeometryReplacer. If you want the arc and line to be part of the same geometry, please wrap them in a <path>:
<geometry>
<path>
    <arcBy3Points>
    </arcBy3Points>
    <line>
    </line>
 </path>
</geometry>
If the two pieces do not join, you can wrap them in a <multicurve> instead
daveatsafe
Forum|alt.badge.img+24
  • Oct 22, 2019 4:46 PM UTC
Hi @philippeb,
<geometry>
<path>
    <arcBy3Points>
    </arcBy3Points>
    <line>
    </line>
 </path>
</geometry>
philippeb
  • Oct 22, 2019 8:45 PM UTC
Hi @philippeb,
<geometry>
<path>
    <arcBy3Points>
    </arcBy3Points>
    <line>
    </line>
 </path>
</geometry>
it's working good thanks a lot!
Is there a documentation about those <path> <multicurve> functions? (And potentially more of them I suppose?)
daveatsafe
  • Oct 22, 2019 9:17 PM UTC
We don't document the FME XML externally, since it can change without notice as we add more capabilities to FME. It's best used to store geometry, or extract info from, rather than create geometry. That said, you can figure out a lot from the XML tab in the Creator transformer, or by extracting FME XML in the GeometryExtractor.
