Create lines from points
  • Oct 18, 2018 4:26 AM UTC
  • 282 views
parashari
I have this where there are start first, end first coordinate(x1, y1) and start second, end second (x2,y2). I simply want to create a line from these points.
I tried using vertex creator and line builder but couldn't get the required thing.
Thanks
Best answer by gio
@hellblazer
for start vertex creator in create mode, for end vertex creator in add mode.
I am assuming the start and end coordinates are related (that is they reside in the same record)
If not, you must merge them on some ID. If you have none, then you need a criteriumn to do so.
  • Oct 18, 2018 5:05 AM UTC
I believe that two VertexCreators do that, if the situation is as I have imagined.
Could you please explain the situation more specifically?
oscard
Forum|alt.badge.img+23
  • Oct 18, 2018 6:23 AM UTC
What is exactly the required thing? Using VertexCreator to create the points and using LineBuilder to join them into a line should have worked. Maybe the point order is not correct?
gio
Forum|alt.badge.img+15
  • Oct 18, 2018 3:17 PM UTC
@hellblazer
