Create lines from Coordinates stored in a Table
chris_m
Participant
I have table that contains records with among other things  a Origin X, Origin Y, Destination x, and Destination y, values as separate fields.  I would like to take this information and create line feature for each record from this data.  Is there a transformer that can do this or do I need to combine the Origin and Destination fields into a single X and Y coordinate first?
  • May 31, 2013
Hi Chris,
one way could be by using a 2DPointReplacer on OriginX / OriginY, followed by a 2DPointAdder on DestinationX / DestinationY. This should give you a line connecting the two coordinate pairs.
If you need to join these line segments too, take a look at the LineJoiner (hint: your input needs to be sorted first).
David
fmelizard
Forum|alt.badge.img+18
  • May 31, 2013
Another option you migth consider is the point connector.
