create line from shared polygon borders
  • October 7, 2014
  • 115 views
Is there a recommended way of creating a line from the shared border of two polygons.
I can create a thin polygon representing the shared borders by:
  • remove spikes and slivers
  • buffering and clipping
Result polygons appear correct but, I need lines not polygons. What I really need is the distance of shared border between adjacent polygons.
  • October 7, 2014
There may be several approaches. I would use the Intersector and the Tester after removing spikes and slivers.
Intersector -> Tester (filter the line if "_overlapes" is greater than 1)
Takashi
gio
Forum|alt.badge.img+15
  • October 9, 2014
Intersector might be used.
I often find that this creates bad objects if used straight on the polygons..
U might consider:
SpatialRelator "touch" and test for related_canidates>0 to limit to touching polys.
Then coerce the polys to (poly)lines.
Then LineOnLine overlayer (or Intersector).
test for overlaps.
