Create Grids of the same size
  • January 17, 2017
  • 5 replies
  • 130 views
Trying to create grids in different parts of the world of the same size i.e. 1km in length.
I am using Points which are LLWGS84 as my source and using the "2DGridCreator" I have tried setting the projection to
"SPHERICAL_MERCATOR" also wondered if "_AZMED_" would work, and also wondered about CommonLocalReprojector (but don't have a bounding box set?). I am then wanting to convert everything back to LLWGS84 and then have grids East to West and North to South with the same length i.e. 1km. current output creates the grids but the length changes in different parts of the world?
Any suggestions to set a static length ?
jdh
Forum|alt.badge.img+41
  • January 17, 2017
Are your grids appearing rectangular in LLWGS84, or are they appearing square which indicated that the ground distance is varying?
  • January 17, 2017
currently I have done the following:
get point location, generate buffer, (to get the bounding box (BoundingBoxAccumulator)) use reporjector destination "_AZMED_" use CoordinateSystemExtractor to get the projection, get the centre point location of the buffer (i.e.. the original point), extract the XY (in the new projection), use the XY and the new projection in the 2DGridCreator, and set the number of rows / columns and set width and height (now in metres), then trying to reproject back to my original LL-WGS84 projection, but it basically puts it in 0,0 position, (using read from source option), if put in the projection I have generated e.g. _AZMED_WGS84_37.52627508_55.7683228358381 this comes up with an error ( I was wondering if I need a revised projection as I have generated new geography i.e. grids from the original Point location?
error msg:
Reprojector_2(TeeFactory): Reprojector_2: Reproject: Could not reproject the geometry of the preceeding feature: Reprojector: Could not create reprojection engine
jdh
  • January 17, 2017
Have you looked into the 2DGridAccumulator>
I would suggest Points->Reprojector(equidistant projection of your choice)-> 2DGridAccumulator (Grid Type Cell Size, ColumnWidth, Row Height both 1000, Type of Grid Polygon) ->Reprojector(read from feature to LL-WGS84).
You may wish to buffer you points to ensure padding of the grid.
  • January 18, 2017
I did a similar approach using 2DGridCreator as that also allows me to se the number of cells plus the size, but doing that I get different sized grid in different parts of the world as I assume my projection is trying cover the world and loses accuracy over a local projection once it is converted back to
LL-WGS84
jdh
  • January 18, 2017
LL-WGS84
If you are using a AZMED, then yes it will lose accurancy the further away from the origin it is.
Is your data continous? ie you want grids that cover the entire world, or do you have specific areas of interest that are scattered all over the place, but not contiguous? If the latter, you will have much better accuracy using location specific projections. If not, an equidistant cylindrical projection should give you the best results. I would try the miller projection.
