create empty folder in zip file
  • May 15, 2020 11:44 AM UTC
  • 566 views
zzupljanin
Forum|alt.badge.img+5
I'd like to create an empty folder in zip file that my files are going to be written.
zip file location is defined as published parameter and used as prefixed parameter of every writers destination parameter, e.g. $(zipfile_location)\\lines.gml AND $(zipfile_location)\\data.dwg)
Cheers,
Želimir
You can do a post process using 7zip (https://www.7-zip.org/ ). It will give you far greater control over the end result.
7zip command line to add everything in a folder including empty directories to a zip file.
7z a -tzip -mx1 -spf2 {filename}
zzupljanin
  • May 18, 2020 11:02 AM UTC
I don't understand. Let me try to re-explain.
I create a zip file with data called data.zip. Inside are gmls, dwgs... whatever.
I'd like to add an empty folder called Style in data.zip.
Here's the workflow I follow when I need to include a folder structure in a zip.
Create a batch file;
1. Execute the workbench
2. Create empty directories
3. Zip
4. Remove empty directories
Example batch file run.bat
fme C:\_Fme_Help\empty\empty.fmw
md C:\_Fme_Help\empty\Data\Empty_Folder_1
md C:\_Fme_Help\empty\Data\Empty_Folder_2
md C:\_Fme_Help\empty\Data\Empty_Folder_3
md C:\_Fme_Help\empty\Data\Empty_Folder_nth
7z a -tzip -mx1 c:\_fme_help\empty\test.zip C:\_Fme_Help\empty\Data
rd C:\_Fme_Help\empty\Data\Empty_Folder_1
rd C:\_Fme_Help\empty\Data\Empty_Folder_2
rd C:\_Fme_Help\empty\Data\Empty_Folder_3
rd C:\_Fme_Help\empty\Data\Empty_Folder_nth
Results are a zip file including the empty folders
Other zip programs can add empty folders but 7z is the best for command line.
zzupljanin
  • May 20, 2020 12:57 PM UTC
3. Zip
This will work for now. I applied a Python shutdown script that basically does what you suggested.
Thank you
