create dynamic xml attribute names
  • December 21, 2018
  • 76 views
pratsch
I'm trying to create a single xml template that can handle dynamic attribute names. The attribute name to be used is stored in another attribute. Please have a look at how i set up the xmltemplater to write the attributes names:
ROOT:
<root>
<a>head</a>
<feat>
{fme:process-features("SUB")}
</feat>
</root>
SUB:
<f>
<{fme:get-attribute("attr")}>{fme:get-attribute("value")}</{fme:get-attribute("attr")}>
</f>
Where 'attr' holds the attribute name and 'value' the value.
I get the following error:
The following error occurred near line 2, column 6 of the query:
invalid expression: syntax error, unexpected character "{"
An error occurred while parsing the 'SUB' sub-template
So clearly this is not the way to go. Is this possible in anyway or do I have to define specific SUBs (conditional) for every possible feature schema?
Thanks!
Best answer by takashi
The computed element constructor might be what you are looking for. Try this SUB expression.
<f>{
    element {fme:get-attribute("attr")} {fme:get-attribute("value")}
}</f>
See here to learn more: 3.9.3.1 Computed Element Constructors -- XQuery 3.1: An XML Query Language
gio
Forum|alt.badge.img+15
  • December 21, 2018
you have attributes in the tags?
Maybe create the template as a attribute and then add to the template?
@Pratsch
Should not the tags be created trough the template? Not via attributes?
I'm no expert on this, but referred to
https://knowledge.safe.com/articles/30940/xml-writing-with-xmltemplater.html
  • December 21, 2018
<f>{
}</f>
pratsch
  • December 21, 2018
Works like a charm! Thanks @takashi
frro
  • March 2, 2021
<f>{
}</f>
Wow!
Just wow!
And thanks a lot!
