Create Cubic Bezier Curves
  • June 24, 2013
  • 177 views
I have to transform a series of points to a line consisting of cubic Bezier curves. I couldn't find a function to do that in existing transformers or the Python API of FME Objects. The Generalizer (NURBfit algotirhm) creates a spline curve, but it's not exact cubic Bezier curves. The expected line has to pass through the both ends of each 3 segments.
  So, I wrote the following script. Is this the "re-invention of the wheel"? If you know an existing function (transformer or Python function) that creates cubic Bezier curves based on control points, please let me know.
import fmeobjects   class CubicBezierCurveReplacer(object):     def __init__(self):         self.set_coefficients(32)              def set_coefficients(self, n):         self.n = n         r = 1.0 / float(self.n)         s = range(0, self.n)         self.k0 = [(1.0 - (r * m))**3 for m in s]         self.k1 = [3.0 * (r * m) * (1.0 - r * m)**2 for m in s]         self.k2 = [3.0 * (1.0 - (r * m)) * (r * m)**2 for m in s]         self.k3 = [(r * m)**3 for m in s]              def bezier_coords(self, p):         coords = []         x0, x1, x2, x3 = p[0][0], p[1][0], p[2][0], p[3][0]         y0, y1, y2, y3 = p[0][1], p[1][1], p[2][1], p[3][1]         for i in range(1, self.n):             x = self.k0[i] * x0 + self.k1[i] * x1 + self.k2[i] * x2 + self.k3[i] * x3             y = self.k0[i] * y0 + self.k1[i] * y1 + self.k2[i] * y2 + self.k3[i] * y3             coords.append((x, y))         return coords              def input(self, feature):         # If the number of coordinates is less than 2, return nothing.         if feature.numCoords() < 2: return                  # Get all coordinates of the input feature as control points.         points = feature.getAllCoordinates()                  # Append coordinates while (number of control points - 1)         # is not divisible by 3 evenly.         while (len(points) - 1) % 3 != 0:             points.append(points[-1])                      # Create  cubic Bezier curves.         bezier = feature.cloneAttributes();         bezier.setGeometryType(fmeobjects.FME_GEOM_LINE)         bezier.setCoordSys(feature.getCoordSys())         bezier.addCoordinate(points[0][0], points[0][1])         for i in range(3, len(points), 3):             bezier.addCoordinates(self.bezier_coords(points[i - 3 : i + 1]))             bezier.addCoordinate(points[i][0], points[i][1])         self.pyoutput(bezier)              def close(self):         pass -----
Takashi
Best answer by takashi
... found a solution. Using the Chopper, break an input line into lines each of which consists of 3 segments (4 vertices), then create spline curve for each line via Generalizer. I re-invented the wheel, just as I feared. I lost a half of a day (:-( Thanks.
Takashi
  • June 24, 2013
Takashi
geo-x
  • August 28, 2018
Takashi
Dear @takashi your solution is great, but my Generalizer doesn't work, I tried some configurations but my segments don't change :-(
geo-x
  • August 28, 2018
Takashi
This is my case geojson2none.fmwt and I need to keep all original vertices.
Thank you for your help.
  • September 9, 2022
Posting the reformatted code here for posterity.
import fmeobjects
     def __init__(self):
         self.n = n
         coords = []
         return coords
     def close(self):
         pass
