Create an excel file before opening it
  • May 28, 2018 2:37 PM UTC
  • 53 views
I have an FMW file that runs various SQLexecutors and produces an excel file. Once the file is created I would then like to open it for the user to view/edit/save etc. I have the transformers to do all this, the problem I have is delaying the opening of the file, calling the SystemCaller transformer AFTER all the SQLexecutor transformers have been run and the excel file has been created.
Thanks
  • May 28, 2018 2:39 PM UTC
Try using the FeatureWriter rather than the regular Writer. You can then let the summary feature trigger the SystemCaller.
lars_de_vries
Forum|alt.badge.img+10
Or perhaps you could use a python shutdown script to open the file.
