Create a column with values from another column
salvaleonrp
Forum|alt.badge.img+23
Looking for a single transformer solution on this question. I have an ordered list and I'd like to populate Col 2 (group) with values from Col 1 that start with '# '. Since the number of rows for each group is random and the categories are also dynamic I'd like to avoid hard coding the groups as conditional values.
Best answer by ebygomm
You should be able to use adjacent attribute mapping in an attribute creator. Use a conditional statement to set the value of column 2 to equal column 1 if it begins with #, otherwise use the value from the previous features column 2
Capture
Forum|alt.badge.img+54
  • March 23, 2021
Capture
salvaleonrp
Capture
Is Col2 in your schema already or created before the AttributeCreator transformer?
  • March 23, 2021
You don't technically have to create the blank column Col2 in advance to populate, but if you don't you'll get the correct result but a red cog on the transformer.
I think if you have FME 2020 you may be able to create it in the same attribute creator
salvaleonrp
That explains it. I have to manually type the Col2 prior feature attribute because it does not show up on the attribute list even if I enabled Advanced Editing. I did get the red cog and the warming during translation but it ran with correct results. Thanks!
