Create 3D block of point cloud extents
  • Oct 25, 2017 12:16 PM UTC
  • 5 replies
  • 103 views
I am trying to create 3d block of the point cloud extents and not really getting anywhere. I was wondering if anyone would be able to help me in achieving this
Thanks,
Sam
Best answer by redgeographics
You can use a PointCloudPropertyExtractor to get the min/max x,y and z values. Then a 2DBoxReplacer to create the 2D bounding box from the min/max x and y, a 3DForcer to set that to the min z value and an Extruder to extrude it to max z - min z
pointcloudextents.fmw
Hope this helps.
Forum|alt.badge.img+63
Hope this helps.
Hope this helps.
That's does the job perfect thanks! How would I go about using this with multiple files for the input to create one dgn file that has all these individual blocks in?
It does that already: just select more than one input file for the reader and add a DGN writer.
Hope this helps.
Ah yes so it does! Thanks very much
Hope this helps.
Hi RedGeographics, is there a way I would be able to write in the name of the point cloud into the 3D polygon that has been created as an attribute?
