Create 3 band raster from one band which contains a palette
  • Nov 4, 2019 12:53 PM UTC
  • 182 views
Hello. I have a b/w raster with only one band but in each band there are 255 palettes with a RGB combine each one. Is it possible extract each combine like a RGB combine value?
Thanks a lot.
This is the example of the issue.
Best answer by takashi
Hi @topo79, if the one-band raster contains a palette already and you need to convert the raster to RGB 3-band raster according to the palette, you can use the RasterPaletteResolver to do that.
  • Nov 4, 2019 1:15 PM UTC
  • Nov 5, 2019 6:11 AM UTC
Hi Takashi.
I´ll try it and tell you how gone it!!
Thanks a lot.
Regards.
  • Nov 8, 2019 12:53 PM UTC
Hello Takeshi. The answer which you tell me last day works perfect.
Thank you so much for your help.
Regards.
