Hi Guys
I am trying to count the occurrence of a value across a large number of attributes. All the attributes have a different name, however they all have "_SIG" in their name (a value that rates significance). Ie ENVIA_SIG, WATRF_SIG etc. There are heaps of them and I want a way to just test those attributes using a wildcard of sorts.
Basically I would like to use a tester to test for the existence of the number 5 in all attributes that end with _SIG. However in the tester (or Test Filter) I have to manually add each of those attributes which is not realistic as there are over 50 of those attributes.
Any suggestions would be greatly appreciated!
Thank you
Dominique
