Count of Attributes with irrespective of schema
  • May 6, 2020 4:15 AM UTC
  • 112 views
pratap
Forum|alt.badge.img+12
Hi Guys,
Can any one guide me on how to perform "INPUT" I have to as "OUTPUT" I require...
Input will be GDB object class table
Output will be excel spreadsheet.
Schema of the table will be dynamic as I will use different tables. I have provided spreadsheet as an example to understand better...
Thank you
Best answer by bwn
From the sample shown:
  • Transform the Input into the required Attribute Name vs Value table using AttributeExploder
  • Create the Summary version of this that counts the number of unique values for every Attribute Name with StatisticsCalculator (or InlineQuerier by using a Count(*) in the SELECT Statement with a GROUP BY Attribute Name, Attribute Value)
bwn
Forum|alt.badge.img+26
  • May 6, 2020 7:08 AM UTC
pratap
  • May 8, 2020 5:48 AM UTC
Hi @bwn,
StatisticsCalculator cant be used because of dynamic schema but Inline querier can be used.
Thank you
bwn
  • May 8, 2020 8:48 AM UTC
Hi @bwn,
Thank you
No problems. Noting, however, that the Output Port of AttributeExploder is a fixed Schema. There are only two Attributes output:
  • _attr_name (Attribute Name)
  • _attr_value (Attribute Value)
However, InlineQuerier is usually a bit quicker than StatisticsCalculator in any case, it just requires a bit more knowledge of SQL syntax. So if that is working for you, then use that.
Otherwise, StatisticsCalculator can be used without the need for writing SQL more comfortably, but with a performance penalty although I believe Safe is looking to accelerate its performance soon in within later versions of FME.
