count objects with the same geometry
  • January 30, 2014
  • 5 replies
  • 107 views
I have a point dataset where I would like to count all objects which have the same attribute (in this case year of birth) and same geometry. The result I want to have into a new point dataset with an unique point for every combination of year of birth and geometry with the count-result into a new attribute. I have looked if I can use Aggregator, Matcher or Counter but I don´t know how to fix this.
Best regards
Ulf
  • January 30, 2014
you can use the Matcher, the output port SINGLEMATCHED will forward one feature for each duplicate match on geometry and attribute. You can then convert this into a point using e.g. a CenterPointReplacer.
In the Matcher, specify an attribute name in "Match count attribute on SingleMatched output", this will contain the number of duplicates.
David
  • January 30, 2014
Addition to David's suggestion.
If you are using FME 2014, be aware that there is a bug in SingleMatched port of the Matcher.
There is a strange attribute "$(SINGLE_MATCHED_COUNT_ATTR)", and match count attribute which you specified will not be displayed.
A workaround I can think of is:
1) Expose correct match count attribute name using an AttributeExposer.
2) Remove the strange attribute name using a BulkAttributeRenamer with this expression.
Expression to Remove: \\$
Takashi
  • January 30, 2014
Sorry for a typo. "BulkAttributeRemover" is correct.
2) Remove the strange attribute name using a BulkAttributeRemover with this expression.
  • January 30, 2014
Hi, both
Thank You for answer. It did work well, and I haven´t recognized the problem with the strange attribute although I see that it was there. I made an attribute (Quantity) in the "Match count attribute on SingleMatched output" and it contained the number of duplicates as I wished.
Ulf H
  • February 2, 2014
I confirmed that  the bug on SingleMatched port of the Matcher has been fixed in FME 2014 SP1 Beta (build 14239). You can download SP1 Beta (and FME  2015 Beta) from Safe site.
FYI.
