Count Number of Points in Each Polygon
  • Jun 22, 2023 5:22 PM UTC
  • 453 views
parashari
Helo FME Users, I am using FME for my data processing tasks, and I am trying to determine the number of points that fall within each polygon in my dataset.
Specifically, I have a set of polygons and a corresponding set of points distributed across a geographic area. My objective is to count the number of points contained within each polygon. However, I am unsure about the most efficient way to achieve this using FME.
Thank you in advance for your time and expertise.
dustin
Forum|alt.badge.img+36
  • Jun 22, 2023 5:35 PM UTC
You can use the SpatialRelator, which will give you an overlaps count.
parashari
  • Jun 23, 2023 12:38 AM UTC
Thank you for your response @dustin​. I would like to give all the points a unique value that are within a dissolved polygon of 500m.
featuremichael
Forum|alt.badge.img+9
You can use an PointonAreasOverlayer transformer - if the Buffer has Attributes that are unique - u can use "merge attributes" in the pointonaresoverlayer transformer to give the attributes from the buffer area to the points.
if our buffer areas didnt have a uniqe number or value - you can make an easy number with the counter transformer - use it for your buffer areas to give them an "_counter"-attribute = numbers.
