Count for each row the cells that contain values
  • Jan 30, 2020 11:23 AM UTC
  • 6 replies
  • 352 views
Hello,
I would like to count the amount of cells that contain a value for each row in my dataset. It is basically the COUNTA function of Excel. But I don't know how to apply it in FME.
I have a large table with 100+ columns which looks like this:
DBKAlCaClPbZn10.10.15
1.2
2
0.11
1.330.20.130.41.52.1
Can anyone help me to get the below outcome?
DBKCount132235
Thanks in advance.
oscard
Forum|alt.badge.img+23
  • Jan 30, 2020 11:34 AM UTC
Maybe you could use a NullAttributeMapper with a Regex to detect any value except null or empty. If it is detected, its value could be mapped to "1".
This regex could work:
[\\s\\S]+
But you need to trimm your values first in case they could contain just blank spaces.
EDIT: The StatiscCalculator doesn't work for this, sorry.
Another solution would be adding a second NullAttrubuteMapper after the first one to map null, empty or missing values to 0. Then use a ExpressionEvaluator to make the sum.
Forum|alt.badge.img+54
  • Jan 30, 2020 12:02 PM UTC
It's not exactly what it's designed for, but you can use the AttributeValidator to validate that attribute have a length of 0, this then creates a list for each attribute where the value exists, you can then use a ListElementCounter to find the length of the list which equates to the number of fields with values
  • Jan 30, 2020 2:13 PM UTC
Another thought. Use the AttributeListPopulator from Hub (Set Yes to the Drop Empty Parts parameter) to populate all attribute values except DBK into a list attribute, then count the number of elements with the ListElementCounter.
  • Jan 30, 2020 3:08 PM UTC
Thanks ebygomm. This indeed works!
Thank you takashi, this works too!
  • Jan 30, 2020 3:09 PM UTC
[\\s\\S]+
This indeed also works. But I have more than 100 columns I want to check. So setting up the ExpressionEvaluator will take some time in comparison with the above mentioned methods. Thanks though oscard!
