Count features with API
  • Nov 8, 2016 8:38 AM UTC
  • 5 replies
  • 157 views
jelle
Forum|alt.badge.img+23
before actually reading the features from an API, I need to count the number of features that will enter. Based on the number, I need to split the search envelope into smaller pieces.
When using the HTTPCaller, I use following URL:
https://geo.onroerenderfgoed.be/geoserver/vioe_geoportaal/wfs?request=GetFeature&version;=1.1.0&resultType;=hits&typeName;=beschermde_archeologische_zones
However, I don't see a way to use a clipping envelope here.
When using the FeatureReader, WFS flavour, it is easy to use the clipping envelope, but I do not see how to enter the parameter resultType=hits.
A possible workaround is to set a Max number of features in the FeatureReader. When that number is achieved, go through a loop until it is lower. However, that means that you actually have to download all the objects and it takes more time.
My preferred solution would be a way to use a search envelope in the HTTPCaller. Any suggestions on how to achieve this?
itay
Forum|alt.badge.img+19
  • Nov 8, 2016 8:56 AM UTC
Hoi @jelle, I see only 30 features in the beschermde_archeologische_zones feature type and that the service countdefault is set to 20000 features so you can easly request all the features and then spatially relate them to your areas.
jelle
  • Nov 8, 2016 8:58 AM UTC
some layers contain more than 10K objects and then it starts taking time. This was just one of the layers to be read.
itay
  • Nov 8, 2016 9:29 AM UTC
Then I would use the 2.0.0 version with responce paging to request the features but I doubt if that will sped up things, its usually the onderlaying server/database that is the bottleneck.
mark2atsafe
Forum|alt.badge.img+59
jelle
  • Nov 8, 2016 5:27 PM UTC
That works. Thanks Mark!
