could i add and change the text that i want to write in output file without opening workspace everytime
  • Jul 21, 2021 1:58 PM UTC
  • 63 views
gogopotter90
Forum|alt.badge.img+14
do we have method instead of creator to add text in pdf ouput file ? but i would like to do that without opening the workspace
my text that i want to write in pdf ,it will change and i do not like to open the workspace everytime to change it .
when i am using quick translator ,could i add also empty field and write the text that i want to see in pdf out from workspace .
is there method to do that,because the name of pdf file should change from time to time y.
Thanks for help
FME2018
Best answer by hkingsbury
Two possible ways, use a parameter to store the text you want to add. Then each time the workspace is run, you will be asked to enter the text.
OR
have the text stored in an external .txt file and have hte workbench read that text in. Prior to running he process you add you text to that .txt file
hkingsbury
Forum|alt.badge.img+73
  • Jul 21, 2021 7:30 PM UTC
OR
