Corrupt GML file error
Hello everyone,
I am creating an FME script, the input data are DGN files and the output data are GML files.
I am using the "XMLValidator" transformer which contains a template file used as an example to model and structure the output GML file.
Here's my problem: I need to convert several DGN plans into GML.
1) : When I input the DGN plans created with the Microstation software, the 'XMLValidator' indicates no errors and the output GML file is correct and matches my expectations.
2) : On the other hand, when I input DGN plans created with TopoCalc surveying software, the 'XMLValidator' transformer indicates several errors: (see photo)
- no declaration found for the 'featureMember'" element
- prefix 'gml' can not be resolved to namespace URI".
Error in QGIS when opening the GML file:
".gml is not a valid or recognised data source."
The GML file is therefore corrupted and cannot be opened...
I can't solve this problem.... I'm interested in any information that might help me solve my problem.
Thank you in advance and have a nice day!
kailinatsafe
Forum|alt.badge.img+21
Hello @dozhwal​, thanks for posting! Sorry to hear you're having issues with the DGN to GML conversion. If I am understanding this correctly, Microstation can consume the FME-created GML, but QGIS and TopoCalc is flagging it as invalid? When you mention template file, do you mean application schema?
Moving forward, I think it would be helpful to see how the GML is being created in FME Form. If you're able to share any of the following, that would be great:
  • A copy of the workspace used to create the GML dataset
  • A sample input file
  • A expected output (to see desired structure, elements, etc)
Happy to help, Kailin.
  • July 13, 2023
Hello @kailinatsafe, Thank you for your reply!
Do you have an e-mail address so that I can send you the data ?
Thanks in advance
kailinatsafe
Thanks in advance
Hey @dozhwal​, lets follow up via support case! Chat soon, Kailin.
