We generate certain types of transformers (mostly HTTPCaller) with some attributes prefilled and want our users to be able to copy the content from a file or web source and paste it directly into FME Workbench, or use drag and drop, if possible. We don’t want to use custom transformers, which works, but the overhead would be overkill. The problem is that the paste does not work, CTRL+V does nothing and the paste menu option is greyed out. I tried with a direct clone of a working transformer so the format is correct. If I copy a transformer, paste it into an editor, copy the editors content and try to paste it back to Workbench it won’t work. I don’t know why this does not work but I persume it might have something to do with encoding. Does anyone have a clue how to overcome this issue, or maybe a workaround? Thanks in advance.
Copy & Paste Transformer from file or web content
Best answer by liamfez
I will add that you could also have sets of transformers, already connected together in various ways. Even add a couple readers with example data and save it as a template file. I have a couple workspaces saved in a folder like that for tasks that I do not do very often, and are different enough a custom transformer would not be appropriate, but require a similar set of tools.
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
