Copy a single row into an existing ASCII file (quick way?)
  • December 19, 2017
  • 57 views
Dear all,
I am currently trying to expand an existing ASCII file with a single row. I have an ASCII file with X, Y, Z, R, G, B and an Intensity (Scalar field). My second ASCII file has the same X, Y, Z and Intensity but instead of R, G and B one single row, named Scalar field #2.
I have both files imported as readers in CSV and connected them with an Aggregator. Now I get an ASCII file which has everything I want: X, Y, Z, R, G, B, Intensity and Intensity 2. My problem is, this task takes +40 hours, since I'm dealing with over 40.000.000 data points each row.
Is there a chance to just copy X, Y, Z, R, G, B and Scalar field from ASCII 1 to a file and extend it with Scalar field #2 from ASCII 2? Do I really have to Aggregate the whole process?
Thank you in advance!
Best answer by sigtill
  1. FeatureMerger - with Suppliers first
  2. Remove the CSV WRITER and replace it with a FeatureWRITER to be able to write the features at once - so you dont need to keep all the data in memory. You should be able to write the output-csv as soon as all the Suppliers are read!
Consider replacing the CSV reader/writer with Pointcloud XYZ-format - it should be waywaywayway faster as it stores - have a look at this for more info: https://knowledge.safe.com/articles/1337/reading-point-clouds.html
erik_jan
Forum|alt.badge.img+26
  • December 19, 2017
I believe FeatureMerger is faster than the Aggregator (especially if you read the Supplier first: first in the list of readers).
But if you have an option to read both CSV files as tables in a database (temporarily), you could use indexes to speed up the joining process and then write the join back to CSV.
sigtill
Forum|alt.badge.img+25
  • December 19, 2017
sigtill
  • December 19, 2017
Also - have the SMALLEST dataset as the SUPPLIER - because you need all of them in memory (it seems to be the bottom CSV-file with fewer attributes) and remove all unneded attributes.
  • December 20, 2017
Good morning,
hey you guys are awesome! It didn't even take 24 hours to get an answer to my questions, thank you very much! I will try your suggestions and write the outome into this post.
Have a nice christmas!
Greetings Sebastian
