CoordinateExtractor not giving correct values for GDA94 after using Reprojector
  • Jan 22, 2019 3:09 PM UTC
  • 150 views
andrewandkym
Hello FME gurus
I want to reproject some GDA data to MGA and then reproject back to GDA and extract some coordinates but am getting weird values for the GDA coordinates. I’m confident the problem is with the CoordinateExtractor tool when used in combination with the Reprojector tool.
To test it, I have set up this workbench where I started with a SHP file in GDA94 projection then:
  • Exported the coordinates
  • Reprojected to GDA94 MGA56
Workbench looks like this:
Below is the results. Yellow is the exported data in GDA94 and blue is the exported data in GDA94 MGA56. The blues match, but the yellows don’t, although they should.
Any ideas why the coordinate extractor is giving me the wrong coordinates?
Thanks
Kym
jovitaatsafe
Forum|alt.badge.img+11
Hi @andrewandkym,
Thanks for sharing your question! Would it be possible to share your workspace and sample data?
andrewandkym
  • Jan 22, 2019 11:49 PM UTC
Hi @JovitaAtSafe
Please find files below:
I am using FME 2017.1.0.0
files.zip
jovitaatsafe
Hi @andrewandkym,
Thanks for sharing your data! It looks like the source GDA94 coordinate system is different from the one specified in the Reprojector. The source shapefile has a coordinate system that is specified in degrees called LL-GDA94_0, while the Reprojected coordinate system is set to GDA94 Geoscience Lambert (EPSG 3112) which is in meters. This then accounts for the reprojected points being in the correct location but with very different X and Y coordinates.
Try changing Reprojector_2 to LL-GDA94 and you should get the same coordinates as the source input when reprojecting back to GDA94.
