CoordinateConcatenator / attribute string : limit decimal places
  • Jan 17, 2017 7:31 PM UTC
  • 5 replies
  • 155 views
I'm new to FME (2 weeks) and i have a problem with decimal places in attribute.
I use the CoordinateConcatenator to write my x/y values of line feature (source DGN) to attribute.
Example:
267866.5661 239026.86510000002
267865.27559999999 239026.7414
267865.1519 239025
267866.4424 239025.57460000002
Now i have to restrict the decimal places to 3 (exactly, 0 places included: 239025 -> 239025.000 etc) and then write the attribute to textfile.
I tried:
-) CoordinateRounder before CoordinateConcatenator (no effect), StringFormatter (didn't accept my values -> example)
-) CoordinateExtractor (but i didn't know how to concatenate and format list values, Loop?!, x/y alternation)
-) AttributManager and @Format-function (same as StringFormatter) ....
Now i don't know any more ...
Mayby there is a way to limit all double-values in workspace to 3 decimal places?!
Can someone help me?
Petra
PS: I'm not familiar with python .....
itay
Forum|alt.badge.img+19
  • Jan 17, 2017 7:54 PM UTC
Hi @petra, welcome to the world of FME!
You are on the right track the SringFormatter should work, have a look at the attached workspace.
Hope this helps.limit-decimal-places.fmw
  • Jan 17, 2017 8:15 PM UTC
Hi itay, thank you for answering.
If i have just one int or double value in the attribute (like x or y in your example), the StringFormatter works well. But I have all the double/int values (-> example)
in one attribute and than the StringFormatter tells:
"StringFormatter: @Tcl2 -- failed to evaluate expression `StringFormatter_formatter' -- expected floating-point number but got "267866.5661 239026.86510000002 267865.2755999999"
itay
  • Jan 17, 2017 8:50 PM UTC
I see in that case I would try to identify the different data types and using the correct syntax per type.
  • Jan 18, 2017 8:15 AM UTC
This has been covered quite a few times here already, but it could be that you're running into a basic limitation of floating point numbers, where they cannot accurately express every decimal fraction, leading to tiny inaccuracies and floating poing frustrations.
More info here.
  • Jan 18, 2017 11:16 AM UTC
Hi @petra, I think you may have to decompose each element of the coordinates to format individual values and then reconstruct a string representing the concatenated coordinates. e.g.
See also the attached example (FME 2016.1.3): format-coordinates.fmw
