Coordinate transformation between space rectangular coordinate of different datum plane.
  • June 20, 2017
  • 31 views
Hello,
I want to do coordinate transformation between space rectangular coordinate of different datum planes. And we know there are some transformation models, such as Bursa. I also have the seven parameters for transformation. I have tried 3DAffine transformer, and it can do work. The main point I want know how to define custom coordinate to do this?
Thank you.
Zhu Xinxin
daveatsafe
Forum|alt.badge.img+20
  • June 20, 2017
Hi Xinxin (@smilevigood)
FME's CsmapReprojector transformer can use custom datum transformations when reprojecting between coordinate system in different datums. To define your custom datum transformation, please see the following page:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Coordinate_Systems/CoordSys/coord_sys_custom_transformation.htm
  • June 20, 2017
Hi Dave, I tried CsmapReprojector, some questions:
1. The definition of custom transformation for CsmapReprojector are used for the parameter "Transformation" , but there are another two parameters should be set: "Source Coordinate System" and "Destination Coordinate System". If they are not set corret, the "Transformation" can not load the custom transformation. I don't very clear about their relationship.
2. In the link you give to me said as follows
"this transformation proceeds in three phases. First, the geographic coordinates are converted to three-dimensional Cartesian, geocentric coordinates using the ellipsoid of the original datum. Second, the three-dimensional transformation defined by the seven parameters is applied producing a modified set of geocentric Cartesian coordinates. Third, the resulting geocentric coordinates are converted back to geographic form using the target ellipsoid."
So this step are all coordinate transformation in FME? If I only want to translate three-dimensional Cartesian of two different coordinate system, how to define the custom coordinate transformation?
