coordinate system conversation problem in EPSG 24370?
  • July 19, 2018
  • 29 views
After geolocate in my SketchUp 2017 when I am trying to convert SketchUp file into GML file with epsg 24370 crs it cannot properly convert bounds that's why I lost my location I almost try with every crs of my country I usually face this problem. Please have a look at my fme skp to gml conversition file and direct me for further changes
Thanks.
Best answer by daveatsafe
Hi @anwaralikhanhun,
Normally, if you geolocate the Sketchup file, FME will read it with a custom coordinate system centered around the lat/long you set.
However, you have the coordinate system on the reader set to PAK-IIA/a, which will override the coordinate system read from the file. Please try removing the coordinate system from the reader, and see if that solves the problem.
daveatsafe
Forum|alt.badge.img+20
  • July 19, 2018
@DaveAtSafe Thank you for your support. Its Work For me when I set it to null. I have faced a new issue in my fme translator. when I translate building furniture with setting feature role as interior furniture it cannot translate into city gml file Please have a look at my fme translator
skp2citygml-8718.fmw
