coordinate conversion, z not staying negative
  • August 3, 2015
  • 12 views
trying to convert NGDC HYD93 format data (b93) to ascii text xyz or csv.
using CSV as the target format, i'm using coordinateextractor to expose the xyz values. the problem is, the z value is being converted to a positive value, while it is negative in the original data. I've been plaing with paramaters in both the coordinate extractor, the target writer featrue type, nothing. any thoughts, either preserving the negative value, or multiplyiing the attribute by -1 by a paamater in the writer, or an arithmatic operator for the writer value?
Best answer by david_r
Hi
How are you reprojecting the data? If you're using the CsmapReprojector you can specify if the heights (z-values) are reprojected or not.
David
  • August 4, 2015
Hi
David
