Converting points to existing polygons based on attribute value retaining all unique items
  • February 17, 2021
  • 86 views
ares
I would like to transfer a layer with a number of adress points to the building polygons in which they are located. For each point I would like the corresponding polygon of the building.
With PointOnAreaOverlayer I got the attribute data of the polygons, but how to replace the point geometry with the existing polygons of the buildings retaining all the items (no aggregation)?
Forum|alt.badge.img+38
  • February 17, 2021
If you extract the polygon geometry into an attribute with the GeometryExtractor after the point on overlayer you can use this attribute to replace the point with a GeometryReplacer
  • February 18, 2021
@ares​ The Area output port has the areas. If there are multiple points per polygon, then you can use the Attribute Accumulation list parameter to create a list of the points that related to the area and then ListExploder to split those into separate features.
ares
  • February 22, 2021
Thanks all. Eventually I found the answer in using FeatureMerger by adding the areas as supplier to the points with feature merge type Geometry. This also replaces the original point geometry.
